upgrading to sky+
Discussion in 'Sky Digital TV Forum' started by MAR, Dec 7, 2004.
  1. MAR
    MAR
    hello,just a quick question,if you have a sky subscription with standard digibox,and you got a secondhand sky+ box,can you just phone sky and have the existing card authorised in the new box.Or do they have to send new card.[ having fitted twin lnb,cable etc.]
    cheers for any info.
  2. Docta teef
    Docta teef
    Nov 21, 2003
    1,262
    Manchester
    +56
    You will have to get a new card as the smart card will only work with the box the card is reg'd to. I wouldnt think sky would have any problem with this.
  3. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    I'm pretty sure you can keep the same card. You can move the card across different standard Sky digiboxes no problem and when Sky upgrade Sky+ themselves you keep the same card. Just give Sky a ring.
