Upgrading to Sky +
Discussion in 'Sky Digital TV Forum' started by paulcollins14, Jul 7, 2004.
  1. paulcollins14
    paulcollins14
    Mar 18, 2003
    109
    16
    I am considering upgrading my standard sky box, mainly for improved sound via optical out, I have a couple of questions : will I have to pay another £10/month ? (I pay £40 now)
    Is the picture much improved over the standard Amstrad ?
    Would I be better off buying a standard box that has optical out and just replacing the Amstrad, is it as easy as that ?
    Paul
  2. johndon
    johndon
    Feb 3, 2002
    1,986
    63
    +122
    If you already pay £40 then you should be on one of the packages that entitles you to the free SKY+ sub. However, even if you're not and if you only want it for better sound then don't pay the sub - you'll still get the sound but no recording features.
    Can't say I've noticed that the pic quality is any better than my other (Amstrad) digibox.
    HTH
    John
