Upgrading to sky plus and sky multiroom
G
gooners4life
Hi, I currently have the standard sky digital box. Next week, I am looking to upgrade t a sky plus box, and sky multiroom. I checked on the sky website, and it is £99, and free installation if subscribing to multiroom, which I am doing (otherwise £60). My only question is, will both of the boxes be sky plus, or will I be left with my current normal one, and the new sky plus one. Thanks in advance.
jrisch
Normally you'll get a Sky+ box and your existing digibox will be used for the multiroom. Try and persuade the installer to install dual cabling for the multiroom box so it becomes a simple box swap to put Sky+ in place of the standard box. You'll get a quad LNB which supplies two outputs for the Sky+, and a 3rd is used for the standard box. If he lays the 4th cable it'll make life easier in the future.
Incidentally, I did the same as you but cancelled the multiroom in the cooling off period (on the orders of SWMBO) and didn't get charged for the install retrospectively.
G
gooners4life
Thanks for your help, but I gave them a call and they said I can choose which room the sky plus box goes in to. Thanks again.
