Upgrading to 6.1 but which speaker to buy?
Discussion in 'Home Cinema Speakers' started by dorgan, Mar 11, 2005.
  1. dorgan
    dorgan
    Mar 9, 2005
    124
    +3
    Fronts
    [​IMG]
    Rears / Center / Sub
    [​IMG]
    Not sure what speaker I should buy to make my system 6.1
    Should I buy another center speaker and sitck it in the back or should I buy another rear speaker?
    EDIT: Should have pointed out that the rears have the tweeter on one side and the woofer on the other and are defined as left and right surrounds (not interchangable. Hope I'm making sense.
  2. Mandel
    Mandel
    Well you really can't use one of those surrounds as a single rear speaker (as they are tweeter on one side, woofer on the other) so your best bet is to get another centre speaker
  3. dorgan
    dorgan
    Mar 9, 2005
    124
    +3
    I was thinking the same myself. Needed another opinion.
    Cheers Mandel.
