Upgrading - Sony - Denon
Discussion in 'AV Receivers & Amplifiers' started by johna, Jan 4, 2002.
Tags:
  1. johna
    johna
    Dec 15, 2000
    874
    Kent
    +4
    This might sound like a stupid question - but here goes
    Would you notice, in your opinion, much difference in sound quality (excluding the obvious upgrade to 6.1 and EX) upgrading from the Sony 940 to the Denon 3802?
    When the volume is usually low to medium?
    John
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,494
    United Kingdom
    +2,030
    You should notice a difference, tighter bass, more detail, better separation etc etc
    I went from a Yamaha RXV795A to the Denon 3801 and noticed improvements as above straightaway, i´ve since changed the 3801.
    Not heard the Sony though so cant really comment directly on it.
