S
SiCliffy
Hi all, newbie here so please be kind!
I use my PC for Football Manager and iTunes with a little bit of internet useage here and there. I've recently decided to upgrade to 4gb RAM on my current mobo, a ASUS a8v deluxe.
Unfortunately this mobo doesn't seem to like the 4gb either through age or through a broken slot. Either way, it needs to be upgraded.
I don't want to spend lots on getting a new CPU etc so just want a new motherboard. My current CPU is a AMD Athlon 64 4200+ dual core which is Socket 939.
Can anyone recommend and/or point me in the direction of a cheap Socket 939 mobo whihc would support 4gb RAM?
