Upgrading PC : Required MB / Athlon XP 3200 / 1G or 512 Ram : please help!
Discussion in 'Computer Components' started by thestorm, Oct 3, 2004.
  1. thestorm
    thestorm
    Jul 13, 2000
    547
    East London, UK
    +30
    Hi all
    I need to upgrade my PC.
    I usually purchase my PC Base unit complete from reliable online stores
    like Mesh Computers esp since these places know how to match the
    componets in order to get a stable system and can get the individual
    quality parts cheaply. But they tend to be a little dear esp if all I want is an upgrade.
    My requirment is :
    Mother Board / Athlon XP 3200 / 1G or 512 Ram
    I have researched online and found the Abit Motherboard to be the best
    for the price £46 :
    http://www.microdirect.co.uk/ProductInfo.aspx?ProductID=5853&GroupID=527
    and a SATA high speed drive :
    http://www.dabs.com/uk/channels/components/harddiskdrives/internalide/productView.htm?quicklinx=3GNS
    I need my PC for :
    Photoshop,playing dvds,mp3 playback,making dvds movies of home videos,
    etc so its used quite heavily.
    Id like to start a discussion on what would be the combination to get the
    best out of my system. What ram should I use?
    Where should i buy these components? I was thinking ofdabs & Microdirect
    What do you advice? The last thing i want to do is buy another slighty
    costly base unit only to find I could have done it cheap myself.
    Dell... eww yukk.
    Pls advise.
  2. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,489
    South Derbyshire
    +198
    The Abit motherboard in that link is not a SATA board so the Hard Drive you specify wont work with it.
    Spend a bit more and get the Abit NF7S v2. Buy 2 120Gb Hds instead of one 250GB - save money and increase speed you will.
    Put your OS on one drive and documents on the other.
    RAM - Go for 2x512mb PC3200. Crucial, Twinmoss, Corsair are all good.
    Microdirect are very good. As are Scan. DABS tend to be more expensive.
  3. Embarker
    Embarker
    Apr 19, 2004
    1,676
    Garden of England
    +70
    don't discount an asus deluxe mb they have twin sata.
    xp2500 mobile will o/c to above a xp 3200, i've got 2.41g/400 fsb on mine totally stable and running at 39 degrees fully loaded
  4. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,489
    South Derbyshire
    +198
    True - I have just ordered the Asus A7n8xE deluxe so cant speak for it as yet.
    The Abit NF7s V2 has 2 SATA and is RAID capable as well - I have 2 of these and they are very capable boards. Plopped in a Barton 2500 and overclocked to a 3200 without any grief whatsoever.
