Upgrading Panny 5 Series?
Discussion in 'Plasma TVs' started by GlynH, Sep 5, 2005.
  1. GlynH
    GlynH
    Dec 9, 2002
    280
    +7
    Hi there,
    I want to upgrade my Panny 5 Series and was looking for inspiration... :D
    I was interested in the Panny PV500 but don't need and don't want all the gubbins with it...tuner, built-in speakers etc.
    Is there a display only PV500 available yet (or shortly)?
    I would like to be able to connect a DVI feed directly from my Denon DVD-A11 directly into the panel and also connect the component feed from my AVC-A1SRA that currently serves up Sky+ (via RGB->Component converter).
    A couple of questions though;
    1. Are there any lip sync issues involved with directly connecting the DVI from the A11 to the panel?
    2. Am I able to connect both DVI and Component at the same time and can the panel detect which input is active and switch accordingly?
    Any other info gratefully received.
    Thanks & regards,
    -=Glyn=-
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    5 series a good screen maybe a HD6 7 or 8 would be the upgrade
  3. GlynH
    GlynH
    Dec 9, 2002
    280
    +7
    Just a quick 'Bump' now that Autumn is well & truly here...
    Just what is regarded as the 'display only' PV500 or 435 replacement and how does it perform?
    Thanks & regards,
    -=Glyn=-
  4. UKseless1
    UKseless1
    Mar 9, 2005
    837
    28
    +35
    Glyn - The panel version of the PV500 is the PHD8 and the folks that have them rave about them. Question I would ask is why upgrade now? Why don't you wait until there is some HD content? On the other hand, if money is burning a hole in your pocket then go for it. MEP and Gizlaroc have the panel and both have had previous SD and HD versions of the pannys so offer a wealth of experience.
