Upgrading my AV setup
Discussion in 'AV Receivers & Amplifiers' started by holtehero, Nov 19, 2003.
  1. holtehero
    holtehero
    Sep 10, 2002
    2,795
    Cambridge
    +1,786
    Hi All,
    I currently have a Videologic digitheatre DTS :rolleyes: and have finally decided this is nowhere good enough anymore
    I plan on using my current Hifi speakers (B&W 603 S2's) as fronts and buy some 2nd hand B&W 601 S2's for the rear,CC6 S2's for front and rear centres and a Velodyne VX-10 sub.
    The problem i have is deciding on the amp which would suit me best. I would like it to have component inputs and outputs and be in the £500-£550 range. I would also like to run my Linn Classik through it.
    So far i have seen the following that seem to fit the bill:
    Denon AVR-2803
    Yamaha RXV-740
    Marrantz SR-7400
    Does anyone have any opinions which would be the best option or alternative suggestions before i go and demo/buy anything.
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    have you considered going second hand? At that range you could get a denon 10se which i suspect to be a better sonic performer (minus bells and whistles) than the amps mentioned. Im not sure that it has component in though
    ad
