Upgrading laptop RAM. Help a newbie!
Discussion in 'Computer Components' started by Timmy C, Mar 13, 2006.
  1. Timmy C
    Timmy C
    Oct 10, 2003
    5,626
    +569
    I recently bought a used Mesh badged Mitac 8375 laptop and and would like to upgrade the 256 RAM that's in it. Can someone tell me if this is pretty straightforward and how I know what I should be looking for.
    Please keep in mind my computer knowledge is minimal but I was hoping to buy on ebay and fit myself as I need to keep costs down as I probably won't keep this laptop for long.
    Any advice greatly appreciated.
  2. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
  3. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Yep, can't go wrong with Crucial. Quality memory and guarantees that take into acount unfortunate mishaps!
  4. The Dude
    The Dude
    May 21, 2004
    6,772
    Beverley, East Yorkshire
    +3,241
    another crucial vote from me :thumbsup:
    as for actually installing the ram, it couldn't be easier..
    remove the flap on the underneath of the laptop, pop the ram in the slot.
    There will only be 1 slot available (either will do if 2 available), and the RAM only goes 1 way round.. fit it into the slot, and push it down until it locks in place.
    Sorted.:smashin:
  5. Timmy C
    Timmy C
    Oct 10, 2003
    5,626
    +569
    Thanks everyone!
