Upgrading Hard drive in Pace Twin?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by 9761, Jul 6, 2005.
  1. 9761
    9761
    May 16, 2005
    499
    As im ordering mine either tonight or tomorrow I would like to know if upgrading the hard drive can be done and what hard drives to use and if theres much work needed?
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
  3. 9761
    9761
    May 16, 2005
    499
    Thanks for that,
    If I replace the drive with a bigger one, I take it I will invalidate the warranty on the Pace? if their's any with it?
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,844
    Somewhere in South Yorkshire
    +5,078
    Open the case and you invalidate the warranty. Assuming they can tell you've done so.
  5. 9761
    9761
    May 16, 2005
    499
    Ive just bought the Pace Twin now so it I should get it by monday hopefully
  6. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    There is no seal on the case only on the HD screws - as mentioned in the HD thread
    MHU100AT is the biggest now
  7. 9761
    9761
    May 16, 2005
    499
    What speed does the disk need to be, 4,200RPM or 5,400RPM?
  8. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Usually 4200 rpm drives are for laptop PC's.
  9. 9761
    9761
    May 16, 2005
    499
  10. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Aren't 2.5" drives less reliable than 3.5" drives (i.e. they wear out quicker) ?
  11. 9761
    9761
    May 16, 2005
    499
    All I know that theres a 2.5 20GB hard drive in my Pace Twin and I want to upgrade the size of it but with everything else the same as the origional drive
  12. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Fujitsu HUS/T/U series are the compatable drives, the OS can handle up to 120GB
