Upgrading from VP30 to VP50
TheNightFly
Established Member
I've taken advantage of the DVDO trade-in scheme to upgrade my VP30 to a VP50 and I'm expecting the VP50 to arrive in the next couple of days. To make the switchover quicker and less painful, I'm wondering if it's possible to write down all my settings from the VP30 and use these to setup (even approximately) the VP50?
It would certainly save a lot of time on initial setup and going through a calibration process with each of my sources. Or am I just going to have to bite the bullet and start from scratch?
Allan
redpavlos
Established Member
Yes, tedious but useful to jot a few basics down.
Main ones are the output format, and assigning video and audio inputs etc, as these are common between the VP30 and VP50. Just connect it up in the same way, and then all the basic settings are the same, so easy to going quickly with pictures and sound on all your inputs. You can then adjust the more advanced settings to your liking.
But after having to do it a few times (e.g. whenever there is a firmware update...) I find it's straightforward to just go do it without having to refer to notes.
poggs
Established Member
I had my pioneer plasma isf'd via the vp30, so all the skyHD colour setting etc are 0 on the vp30. The dvd player / ps3 are different.
So my question would be, would the settings on the vp50 need to be re-calibrated or can the same settings on the vp30 be used without mucking up the isf'ing?
TheNightFly
Established Member
redpavlos,
Thanks, it's such a long time now since I set up the Vp30 that I'm no longer all that familiar with the set up process. Sounds like it will be quicker to start with the VP30 settings and adjust from there if necessary.
Allan
redpavlos
Established Member
Good question. Others will be more qualified than me to answer, but I suspect the VP30 settings will be a good start, particularly those at a nominal '0' and I somehow doubt things would get messed up. But I don't know if the colour etc adjustment increments are the same, and my system hasn't been ISF'd.
The VP30 (or VP50) isn't really where you would carry out the fine adjustments needed for ISFing, and I don't think it's been designed with this in mind. It would primarily be in the display device provided it's adjustment capable. Having said that, any unit in the chain will influence the final result.
petes
Established Member
Allan
There's a spreadsheet on dvdo's website http://www.dvdo.com/documents/DVDO_iScanVP30_Settings_Worksheet.xls which helps you make sure you capture all the relevant bits - you still have to re-enter them by hand of course.....
TheNightFly
Established Member
Thanks pete.
My VP50 has arrived! Just lashed it up quickly to verify all is working ok. Looks like it's on firmware 1.00 so need to update this before spending too much time on calibration. Popped some HD-DVD through (Chronicles of Ridick) just to verify HD inverse tele-cine was working. It was, smooth as silk. Couldn't believe how much better the image looks now I'm scaling the full 1080 down to 720, very impressive. If i had to put figures on it I would say it looks about 50% better again than HD did over SD using the VP30. Better clarity and three-dimensionality, even quite dark scenes had plenty of image depth. Very happy with the upgrade.
Allan
TheNightFly
Established Member
Arghhh, spoke too soon. I'm getting the occasional judder at 48Hz. When it happens it seems to happen immediately following a scene change. Already updated the firmware to 1.01 and didn't spend enough time with 1.00 to know if this is a result of the update. Damn... need to do a bit of searching through old threads now.
Allan
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
