Upgrading from HD3 to HD5. Help please!!
Discussion in 'Headphones, Earphones & Portable Music' started by nipbiplip, Jun 19, 2005.
  1. nipbiplip
    nipbiplip
    Feb 5, 2005
    3,430
    On my Manor
    +574
    I have a HD3 which I'm quite happy with, but I have the chance to swap it for a HD5. Will I be able to just plug it in to the PC and re-transfer all the music on sonic stage (3.0) straight to the 5, or will I have to start from scratch by uploading each and every cd I own?
    Also, will my rm elk40 remote be compatible?
  2. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,258
    +64
    Transfer once again. No need to re-rip.
    Yes it's compatible. You might not need it anymore though. I don't really use it with the HD5 now that they've tweaked the speed of scrolling. Your Mileage May Vary.
