Currently I have a CXA-60 with B&W 683 LR setup that I use for both music and television sound. The performance for music is more than satisfactory but we are unhappy with the audibility of voices especially the distinction between voices and other noise in movies. They seem to overlap. The tv is an lg oled 55C7 with Apple TV. The TV is connected to the receiver with an optical cable.
First question: I am under the impression that to improve the voices, I need to add a center speaker. Is this correct or can I do something else. (Tv presets don’t seem to help.)
Then, in order to add a center to the setup I need to pick a center and a new receiver. After reading reviews and getting advice it looks like the Denon AVC-X3700H would be a good fit paired with a HTM6 S2.
Second question: do you agree that this matches the sound of my other speakers and is a good match?
Third question: on reviews here I read that the HTM72 is unequivocally a lot better. But does it match my 683? Can I mix them?
