upgrading from 5 speaker set up with denon 3802 to seven speakers
Discussion in 'Home Cinema Speakers' started by mick23, Mar 26, 2002.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    i have denon 3802 with 5 speaker setup, i wish to take advantage of the dts-es discreet 6.1 etc at present front speakers center and surrounds , surrounds are connected to (a) i have purchased a pair of mission m70s to add to system do i connect to (b) speaker connection or to rear surround do i have to enable multi in system set up thank you
  2. magking
    magking
    Jan 6, 2001
    380
    Norway
    That's one looooooong sentence you've got there.
    But if you're asking to use surround B or surround back for the two back speakers in ES/EX, then the answer is the surround back.
    For the multiroom part, i don't know.
  3. Epithet
    Epithet
    The relevant page of the manual is page 18. I have attempted to attach the page but I am not sure the link works.
    Anyway,
    1. in "Setup", "Speaker Configuration" select "Surround Back" and configure the speakers "small or large" as appropriate.
    2. in "Setup", "Power Amp Assignment" select "Surround Back".
    See also page 21 "auto flag detect".
    Good luck
    Epithet.
