Upgrading from 37" Panny to 42 or 46??
dvdphile
I currently have a 37 PW4 and am considering an upgrade to a more modern panny maybe a 42 or 46".
Could someone please tell me if I can use the same wall bracket as that would make my decision easier!!:eek:
Regards,
Gary
Member252055
It depends what sort of wall bracket you have at the moment. The new Panasonics have different wall mount centres to the older ones so if you have a genuine Panny bracket then the chances are it won't fit. If you have a universal type bracket then it should fit fine as the new fixing points are smaller that the old ones. You also need to make sure the old bracket specs suit the weight of the new TV.
Hope this helps.
Regards
Graham
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
