Upgrading firmware with LG 4040B ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by RecordablDVDfan, Oct 30, 2003.
  1. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,869
    68
    +47
    I've installed a new LG 4040B which has firmware A300. I can't read bulkpag DVD-R's. Would the upgrade to A301 from the LG site help ?
    Also I read that I can't install the firmware update unless :-
    1.Have the GSA-4040B connected to the secondary IDE channel as a master drive alone.
    This is impossible to do on my pc. The master drive is the HDD. The DVD writer is on primary slave does it really matter or not ?
    Has anyone else updated NOT following the above 'rule' ?
  2. lead
    lead
    Aug 19, 2003
    653
    +62
    Why can't you make the LG secondary master? Does your motherboard only have 1 IDE channel? :confused:
    I have just ordered this writer, but I won't get it until next week. :(
  3. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,869
    68
    +47
    JUst an update to this, the DVD-R's read ok but only at 2X though rated for 4x so same question but for diff reason!
  4. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,869
    68
    +47
    I could perhaps but I don't want to screw things up. I also have a DVD-ROM drive and a CD writer also installed
    I don't know why it's nessasary anyway as with a CD writer's firmware upgrade this was'nt an issue which IDE channel you used. Where did you order from btw, hopefully ebuyer!
  5. nwgarratt
    nwgarratt
    May 5, 2002
    26,437
    +2,871
    That is why the firmware exists. It also reads princo at 2x instead of 4x.
    I don't have any need for 4x media, so I still have the original 104 firmware.
