upgrading dht-500sd
stewjoy
Hi.
I Own A Denon Dht-500sd, And I Would Like To Upgrade To 6.1,
I Have Had Various Solutions How To Do This From Shops,
But None Seem To Make Sense To Me.
Could Someone Please Help.
Thanks.
Cable Monkey
You have a passive sub using your 6th channel.
You need to buy a new active sub and use the sub woofer pre out next to the fan on the back.
The output for the passive sub then becomes your 6th channel.
Configure the system as such using the setup menu and put your 6th speaker (you have to buy it) on the 6th output.
stewjoy
thanks cable monkey,
can you sudgest where i can purchase active sub + additional speaker.
denon say they no longer produce these items as a separate purchase.
thanks
stewart
Cable Monkey
You may get some joy getting a second hand speaker. You have the whole world to choose regarding a sub, but if you wish to stay with Denon, the 550 has an active sub. If someone chose to upgrade, these might appear on the second hand market.
