Upgrading AVR300 firmware loses settings
Discussion in 'AV Receivers & Amplifiers' started by Mike999, Oct 24, 2004.
Tags:
  1. Mike999
    Mike999
    Aug 24, 2004
    212
    +13
    I just upgraded my AVR300 from 2.84 to 2.90 . The upgrade went without a hitch (1.12 DSP first, followed by the 2.90 software) . The instructions are fine. However, when the receiver was up again I noticed all the setup settings had returned to defaults and I had to enter them again - speaker types, distances, levels etc. Is this normal? I would have hoped settings would be preserved across releases under most circumstances, unless the code change involves a major change in the way settings are held.
  2. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    Yes you can expect that with a firmware update, since the new firmware may have different settings it's best to clear the NV ram... this is probably one of the reasons why they are reluctant to supply updates to end users.
  3. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    The control SW updates don't usually reset the AVR, but DSP updates do and they are much less common.
    It's always best to keep settings documented. Unfortunately, resets also clear tuner presets which are more of a pain to redo.
  4. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    952
    Scotland
    +18
    Assuming you only updated to fix an actual problem and not just updating for the sheer hell of it, is it such a big price to pay ?
    I have updated firmware/bioses for years and the small inconvenience of remembering your settings is an accepted but minor issue for me.
    The manufacturer is merely giving you a recognised/safe starting point.
  5. Mike999
    Mike999
    Aug 24, 2004
    212
    +13
    No, it's not a problem, this also occurs with many other devices I've done firmware upgrades on (routers, switches etc) - but not always. It's just that it wasn't mentioned anywhere in the instructions - if configurations aren't preserved it's a good idea to say this up front. Didn't take long for me to restore them....
