Upgrading AV32R Software
Discussion in 'TAG McLaren Audio Owners' Forum' started by Matt Horne, Oct 25, 2004.
  1. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,217
    83
    Over the Hill & Far Away
    +137
    Hi...
    Well due to a kind soul I am borrowing a tag cable so I can upgrade the software to 3.80
    How exactly do I do this ? Is it a case of plugging the cable in the Av32 and my pc and then just running the exe I can download from the Tag/iag website ?
    Matt
  2. Joelc
    Joelc
    May 16, 2004
    414
    +5
    Matt:
    The upgrade process proceeds as follows:
    1. Download the Upgrade Wizard and install it.
    2. Download and expand the software you want (which, in your case, is AV32RSP_V380.EXE).
    3. Start up the Upgrade Wizard and follow the steps. Noting, the steps must be followed to the letter otherwise it will not work.
    Hope that helps.
    Joel
  3. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,217
    83
    +137
    Cheers... I presume the upgrade wizard is also on the IAG site ?
    Matt
  4. Teejoo
    Teejoo
    Apr 24, 2004
    221
    The Netherlands
    +3
  5. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,217
    83
    +137
    hmmmm cannot get it to work... it complains about the boot loader...plus I am not sure what com port to use...says I have 4, 1,2,4 seem to be in use?? and com cannot talk the tag...
    I'm using my tosh laptop..
    any ideas ???
    thanks
    Matt
  6. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,217
    83
    +137
    ignore me all sorted :)
