Upgrading And Was After A little Advice
Discussion in 'Home Cinema Speakers' started by betamac, Dec 2, 2004.
  1. betamac
    betamac
    Bear In mind i cannot demo as theres no where anywhere near me which enables me to do so
    I have narrowed my upgrade down to the 2 choices below what is going to give me the best sound quality mainly for home cinema just looking for general oppions of poss
    Choice 1:
    MISSION VOLARE V63 SPEAKERS (PAIR) £399.95
    MISSION VOLARE V61 SPEAKERS (PAIR) £249.95
    MISSION VOLARE V6AS SUBWOOFER £399.95
    ATACAMA NEXUS SPEAKER STANDS (PAIR) £59.95
    Total £1109
    Choice 2:
    ACOUSTIC ENERGY AEGIS EVO 3 SPEAKERS (PAIR) £299.95
    ACOUSTIC ENERGY AEGIS EVO 1 SPEAKERS (PAIR) £149.95
    Total £909.80
    Along with whatever i choose will be mission M5DS Surrounds for 7.1
    And the reason i chose the mission sub in both packages is simply because i need a nice looking sub and the Accoustic sub is very boxy and ugly unfortunately
    Thanks in advance
  2. betamac
    betamac
    P.S does anyone know of a Wooden centre speaker which is 13.5CM high (MAX)
    when putting my plasma above the mantel i mis judged it slightly and got it abit too low the Mission speaker i have now is exactly 13.5CM and fits perfectly but all the wooden centres i have seen are well over that amount but i would love a wooden centre to go with the rest of the kit
  3. tom_nieto
    tom_nieto
    May 21, 2003
    418
    Brighton
    The M5DSs should work fine as rears.
    I think you'll have trouble finding a centre speaker of those dimensions, especially by mission (best to integrate). My mission 78c is about 17cm high and I would imagine my m7c2 was also about the same height.
  4. betamac
    betamac
    Thanks for the reply
    I have edited my original post to show 2 packges i am deciding between if anyone has any advice it would be great
  5. tom_nieto
    tom_nieto
    May 21, 2003
    418
    Brighton
    Why not just the accoustic energy speaker package? It's meant to be very nice. I would have a hard time choosing between the two.
  6. betamac
    betamac
    The problem with the accoustic package is
    1: Centre speaker is too big to fit under plasma so have to stick with current centre
    2: The subwoofer is a big black and pretty ugly box which is going to be on show and i wont get away with that :)
    so i chose the fronts and rears from the package and then just changed the sub (dont know much about subs theres maybe a better one to suit that package?)
