Upgrading Advice
Discussion in 'AV Receivers & Amplifiers' started by sarnison, Oct 20, 2005.
  1. sarnison
    sarnison
    Sep 5, 2005
    24
    Hi all,
    I have a Yamaha RXV 540RDS receiver that I'm looking to upgrade. Does anyone have any recommendations ? Would the current Yamaha 757 provide an improvement or should I go further ?
    I need 3 Component inputs as a minimum.
    It would be driving B&W VM1's and a Tannoy Revolution sub.
    Any help would be appreciated.
    Steve
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    What budget are we looking at here? Any other preferences? What percentage music to movies??
  3. sarnison
    sarnison
    Sep 5, 2005
    24
    75/25 in the favour of movies over music. Budget of around £500.
  4. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    There may be a few 1500 comes down to that price if there are any left to clear the way for the 1600 thats out later this month. The 757 would make a fine choice and i think you may be able to get it from richer sounds with a price match for less £400 nearer £350 if i remember correctly.
    If you could find a marantz 7500 for £500 that would be a bargin too (more musical but still great with films).
  5. IanD
    IanD
    Jun 27, 2002
    122
    Brisbane
    +8
    The Yamaha only has two component inputs so it will not be suitable for you. I am not sure that you will find many amps with three component inputs in the price range of the 757, so you will probably have to set your sights a bit higher. I have a 757 and while I think it is a very good amp, it will not do justice to the speakers you are using like a more expensive amp will.
  6. sarnison
    sarnison
    Sep 5, 2005
    24
    I've decided I can stretch my budget a little (after a tough conversation with the wife!)... the three amps I have in mind are the Marantz SR8500, Yamaha RXV4600 or an ex dem Arcam AVR250.
    I havent listended to any of them yet but will be shortly.
    I'm taking it as read that they will all perform with movies well so it's the stereo performance that may sway me. I take it the Arcam will be best in this area ?
    Anyone have any strong opinions on these ?
  7. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    The stereo performance of the 2500 should not be underestimated, pressing the pure direct button bring delight to me :) Consider the 2600 which will be out soon as your budget will alow.
  8. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    The Marantz should perform well with music also. In fact all of them should.
