upgrade
Discussion in 'Desktop & Laptop Computers Forum' started by dennis, Aug 28, 2003.
  1. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    hi all,
    i have amd 1800xp evesham pc with asus a7v266-e mobo,can someone tell me what the max cpu i can upgrade to without any messing around ,i am not an expert but can manage most things but dont want to mess around with bios etc.
    thanks
  2. Kramer
    Kramer
    Have a look at the Asus site ;)
    That's a 133 fsb mainboard IIRC, so not compatible with newer 166/200 fsb "Barton" CPUs, not without a BIOS update anyway.
    BIOS updating isn't as difficult as you might think.
    Given the cost of new hardware these days, a mainboard & CPU upgrade might be a better option.
    :smoke:
  3. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    it definatly is a better option. An NF7-S and an xp1700 will outperform that pc with any cpu.
  4. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    thank's for help fella's it looks like a new mobo and cpu are the way to go as i really want something like a xp3000+ to play doom3 type games when they come out.but im a bit scared of going this deep into my pc:rolleyes:
  5. Hawklord
    Hawklord
    Feb 15, 2003
    3,441
    Aldershot, Hampshire
    +265
    You'll also need a powerfull graphics card to get the best from the games like doomiii. What card do you currently have?
    With regard to upgrading components (mobo and cpu) you shouldn't have any problems with the change over but you'll probably have to look at buying more ram to utilise the dual channel ddr functionality of the NF7-S Nforce 2 boards. You may need to upgrade your power supply if it's <350watts.
  6. Zef
    Zef
    Apr 24, 2002
    221
    Hertfordshire
    +9
    Sorry to butt in but Im looking to upgrade Mobo and cpu, but how will Windows XP o/s handle this ?.
  7. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    thank's hawklord,i have gforce 4ti 128meg,and i have 1024 ram!should be ok.
  8. Hawklord
    Hawklord
    Feb 15, 2003
    3,441
    +265
    Your usually recomended to do a os reinstall for new mobos so you'll have to format your hard drive reinstall windows xp and all drivers relating to hardware.
  9. Hawklord
    Hawklord
    Feb 15, 2003
    3,441
    +265
    I can't imagine you having too many probs with that spec but hopefully the new games will be scaleable anyhow. We might just have to reduce the res or switch a few of the eye candy options off. Still hopefully with my spec (Xp2800+ 1024 pc 3200 ddr dual channel with a radeon 9700 pro and nf7-s mobo) it'll look the dogs dangalies.:devil:
  10. Pulsar
    Pulsar
    Jan 19, 2003
    2,925
    West Midlands - Stourbridge
    +292
    Another vote here for the NF7-S mobo. Mine has been rock solid stability wise, and is sooo fast. IMO, to get the best value out of this mobo, you should find a Athlon XP1700 or XP1800 that can be overclocked easily. I have a JUIHB XP1700 running at 2400 Mhz. This processor, when combined with fast RAM (In my case Corsair XMS) will give very impressive results.
    Have a look yourself, a google search should give some useful info.
    Rob
  11. Hawklord
    Hawklord
    Feb 15, 2003
    3,441
    +265
    or go to www.overclockers.co.uk forums for any advice/research- I've found them to be an invalueable source of information.
