upgrade
Discussion in 'Video Streaming Boxes & Services' started by danny-p, Jun 6, 2003.
  1. danny-p
    danny-p
    Ive just got a new alpine cd player (60wx4), infinity 6x9's (200w), A 600 watt amp and crappy standard door speakers ( nissan micra's own).
    The system sounds good but the more the volume is upped the fronts start to vibrate/distort. Ive moved the fade to the rear more which solves this but the vocals now sound way too weak.
    Can anyone recommend a good pair of front door speakers that should fit without any mods and sound the dogs? (nissan micra 2000 edition)
    cheers in adv..
    Danny-p
  2. backtothefuture
    backtothefuture
    in my ICE I got a pair of front components , Boston Acoustics FS60 and they are the bizness! Give crystal clarity and excellent bass response .
    A bit of a budget stretch at £175 for a pair though ... they're 6.5" , how big are the front speakers for your Micra?
    (Can definitely vouch for those Bostons though)
  3. danny-p
    danny-p
    thanks for that Backtothefuture,
    Not sure what size my standard fronts are (havent peeled door insides back yet), but will check tomorrow.
    Where did you buy yours?
