Upgrade time! Processor or bigger amp?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Timmy C, Jan 12, 2004.
  1. Timmy C
    Timmy C
    Oct 10, 2003
    5,209
    +408
    Since getting a projector its given me the urge for better sound and need some advice from those in the know. At the moment I'm using a Denon 3300 receiver but the main left and right channels are going via my main hifi to Monitor Audio 8i speakers bi-amped with 2 Arcam 10p power amps. One of these is a 10p3 which is also powering my center channel. What I'm wondering is if these amps would be suitable to use with a high end processor (I was thinking of spending around a grand on a second hand Tag or something similar) or are they going to be outclassed. Would I be wasting my cash and if so can you recomend a better option.
    One more thing, I could do with component video switching.
