upgrade query...
Discussion in 'AV Receivers & Amplifiers' started by Mr Cat, Aug 17, 2005.
  1. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,215
    Weardale
    +57
    ok, you know what kit I've got by my signature...
    I could possible upgrade my av amp, however, the setup I run is as follows-
    my Nad c350 drives my main speakers, so when I watch a dvd I connect both amps (nad stereo and yammy av amp) so that the the yammy actually drives the centre, reads and sub...
    I forget the exaxt connect names in the amps that I use to connect - I think they're the main and pre connectors..? anyway, I only have to use the av remote to control the volume, and I think I have about 15-20% improvement using both amps that just using the yammy for dvds...
    this leads me to the question - do I actually need to upgrade my av amp..?
    I'm gonna stick with 5.1 - due to rooms size issues...
    what kind of improvments can I expect if I do upgrade..?
    cheers
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Not that you need it but a significant upgrade in stereo ability over the old 620. Better surround steering and processing power and better/bigger power amps for driving the speakers. Most of the newer processing from :dd: and :dts: are aimed at more than 5.1 unless you want :dts: 96/24.
    If none of that apeals to you you might be better off just getting a power amp and bi-amping the front speakers with it. Makes quite a difference :devil:
