Upgrade path - advice appreciated
Shooter1
Hi everyone
I've decided to see if it would be worthwhile upgrading separate components of my current system & would appreciate advice on the order to do it as well as recommendations.
My current set up is: denon 1311 amp, with a front 3 of Q acoustics 2020i and the Q acoustics 2000 ci centre, the rears are a couple of old satellites from a Denon 5.1 system and the sub is a canton from a 6 yr old 5.1 system.
I've only just bought the front 3 to replace the front 3 that came with the denon 5.1.
The system is mainly used for watching SkyHD, watching a blu-Ray on the weekend and also listening to music, which is currently provided by connecting airport express to the Receiver.
I thought about upgrading the receiver to the Denon AVR-X2000 as this can be had for £249.
Will this see a significant performance improvement and in particular for music and blu-ray playback?
After the receiver, I was wondering whether I should upgrade the sub and if so, was looking for recommendations around the £250-£300 budget.
Thanks in advance for all replies
PSM1
The X2000 should be a good improvement over your current receiver so well worth the £250 in my opinion. Your budget for the sub will get you a BK Electronics Gemini II or XLS200 and both will be a good upgrade over your current one. I would say stretching to the xls200 is well worth it and will mean you will not need to upgrade the sub for some time.
Goldenbone
If you watch a lot of films, the sub is going to make a huge difference. I'll echo the above and say go for a BK model - I've had a Gemini and I've got a mono+ now! and they represent crazy value for money.
