upgrade or not
Discussion in 'Blu-ray & DVD Players & Recorders' started by dodo007, Apr 30, 2007.
  1. dodo007
    dodo007
    Mar 14, 2007
    1,029
    38
    +19
    I have a pioneer 433 dvd/hdd and i like it very easy to use .PQ is not top notch but still good.
    Is it worth me upgrading to say a Panasonic DMREX75 or waiting for a hi def played / recorder.
    I am viewing all this on a panny 50inch px60 from 9 feet away
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,474
    2
    +1,367
    If this is your manual I hope you have connected the Player to your DVD via component for the best picture. http://www.service.pioneer-eur.com/peeservice/instrmanuals.nsf/0/50715ABF2D687605C125701F0030DCAF/$File/VRB1379_DVR-433H-S.pdf
    Page 94 of your manual
    "Component Video Out Interlace •
    Select if your monitor/TV is not compatible with progressive-scan video.
    Progressive
    Select if your monitor/TV is progressive-scan compatible. Check the operating instructions that came with your monitor/TV if you’re not sure.
    For Component Video Out to be effective, the AV1 Out setting (see below) must be set to something other than RGB
    AV1 Out Video •
    Sets the AV1(RGB)-TV SCART output to standard composite video
    (compatible with all TVs).
    S-Video Sets the
    AV1(RGB)-TV SCART output to S-video. Recommended if you
    are using a long SCART cable.
    RGB Sets the AV1(RGB)-TV SCART output to RGB. Good quality but check
    your TV for compatibility.
    If you choose a setting that is incompatible with your TV you may not be able to see any picture at all. In this case either switch off and reconnect
    using the supplied video cable, or reset the recorder (see Resetting the recorder on page 111).
    The Component Video Out setting (see above) has no effect when AV1 Out is set to RGB.
    Remember it's progressive out you are looking for. You will also need an audio lead.
  3. dodo007
    dodo007
    Mar 14, 2007
    1,029
    38
    +19
    i do have it connected via componet seems fine no difference to copomsite
