Upgrade or Downgrade
Discussion in 'AV Receivers & Amplifiers' started by martinoslice, Jun 8, 2008.
  1. martinoslice
    martinoslice
    May 26, 2007
    457
    portstewart n,ireland
    +4
    Hi, im currently using a pioneer lx70 for processing combined with a rotel 1095 power amp, i would love to try out some of the lexicon gear as i hear its great for hc, but its way to expensive.
    I was checking out the lexicon rv-5 integraded which does hdmi which i need but its only 7 x 80w, would this be a downgrade, it would be powering the kef xq1 series with a xq2c centre.
    Or should i hold out to see what hd processors arrive this year, i liked the look of the rv-8 but no hd so no good.
  2. martinoslice
    martinoslice
    May 26, 2007
    457
    +4
    Anyone!
    I do realise going from seperates to an integrated is a downgrade, but would that be the case with the likes of the lexicon.
