Question Upgrade old PC or not?
Discussion in 'PC Gaming & Rigs' started by cymru78, Oct 1, 2017.
Tags:
  1. cymru78
    cymru78
    Jul 3, 2011
    Once upon a time I was in to games. I was also up to date on PC specs but this no longer applies!
    Nowadays, I just don't have time to play them and I don't enjoy them as much anyway. Just sold my PS4 actually because it's hardly used anymore.
    However, my young kids are starting to get in to the usual games like Minecraft and Rocket League and Football Manager.
    I'm thinking of buying a PC for casual gaming.
    I've been offered an old Dell Vostro 420, Win 10, 1tb hdd, 2.6ghz quad core q9400 & Geoforce 9800gt graphics card for around £100.
    Is there honestly anything I could do with this to make it a bit more modern and have it working for those particular games at all?
    If this can't be done (as I presume) is there a budget PC that anyone can recommend for me for approx £350-500?
    Ideally, pre-built as I don't have the time to build one myself.
  2. Delvey
    Delvey
    Jul 20, 2008
    9,431
    Manchester
    +3,000
    I don't think the used PC will.be any good. Have a look at the sticky at the top of this section. It's a little out dated but the information is still pretty good. For £500 you need to build yourself. And it should only take an hour or so
  3. cymru78
    cymru78
    Jul 3, 2011
    Thanks for the reply.
    I've had a check done with System Requirements or whatever that website is called.
    Says Minecraft will be fine and meets min requirements for rocket league
    Is there not a way to upgrade it slightly?
    Add ssd, maybe newer graphics card and a little bit more ram?
  4. Delvey
    Delvey
    Jul 20, 2008
    9,431
    Manchester
    +3,000
    You could get a newer GPU. As long as the PSU is decent. I wouldn't bother with an SSD. How much RAM does it have?
    For £100 I would give it a go. The problem is if the kids get hooked on games then you'll need to upgrade anyway
  5. cymru78
    cymru78
    Jul 3, 2011
    6gb RAM. I just thought a cheap SSD to store Windows would be best?
    What Graphics would you recommend should I buy it?
  6. cymru78
    cymru78
    Jul 3, 2011
    I've just been informed that the graphics card has been replaced with a Radeon HD 4890.
  7. Delvey
    Delvey
    Jul 20, 2008
    9,431
    Manchester
    +3,000
    Unless you are bothered about boot times and load times I wouldn't bother with an SSD. A 4890 should be sufficient for those 2 games you want to play. 6GB should be enough as well
  8. cymru78
    cymru78
    Jul 3, 2011
    Thanks for your help. I really appreciate it.
  9. UK Hawke
    UK Hawke
    Previously Cooper85
    Sep 30, 2017
    10
    Cornwall
    For £100 it may be worth a punt! Atleast for starting out
  10. ShadowZeka
    ShadowZeka
    Oct 8, 2017
    12
    Sandy ,Bedfordshire
    You can find on ebay i5 2nd generation computer with 4-8gb ddr3 500gb hard drive for about £80-100 and buy gpu for £30-50 max like gtx 750 or gtx 750 ti. Will be much better than that Dell Vostro 420 :)
