I have a well established and working loftbox (Global TV Link) TV/Sat/Radio distribution system around the house. My Sky service is bog standard Sky (no PVR, HD etc). I am about to upgrade to Sky+HD.
The loftbox has a single SAT input, which is currently fed from the dish, then the combined signals feed down into the lounge via one cable where the signals are split out by an appropriate wall plate.
I understand for a Sky+HD install that the LNB is replaced with a Quad and two downleads are required. It also seems from other posts that the Sky installer will not go near a loftbox, even with gentle persuasion (or bribery
1. Can anyone confirm my understanding above is correct?
2. If so, do Sky fit two separate cables for +HD or is it a twin/joined one?
3. Assuming Sky+HD will be installed as above (no loftbox connection, and direct cable from the LNB to a new 'standard' lounge wall plate feeding the new box), is there any point in trying to re-wire after the installer has gone i.e. to get one of the new downleads into the loftbox? Obviously I currently have the Sky box RF2 output feeding back up into the loftbox, and this will still work on the new Sky box, so is there any benefit on the new setup with having one cable from the LNB going via the loftbox?
