Johnbigbooty
Hi all, noob to avforums here. Been reading and listening and now I have upgrade-itis
This is my office/computer system, mostly music but the occasional game or movie and I could use some help to make sure I'm looking in the right direction equipment-wise.
Edit: 95% of the time I'll listen to speakers, headphones not so much.
A few months ago I upgraded from a Logitech Z263 2.1 system ran off my pc soundcard to Edifier S350DB 2.1 speakers run off a Soundblaster X3. That was a big improvement so naturally now I want more
I gather the next step would be a dac/amp setup-- is that what you'd recommend? Also, thinking real hard about the Edifier S3000 Pro speakers. If I got them do you recommend still getting an amp? And dac-wise-- suggestions? The X3 actually does a decent job with the S350DBs so what's a worthwhile upgrade from that or should I just stick with the X3?
Another question is about the S350DB sub and how it would work with the S3000 Pros? Would I be able to make everything work together in a 4.1 configuration?
Thanks very much.
Thanks very much.
