Upgrade Infocus 76 to Optoma hd33
d0mm13
Hi my Infocus 76 has just died and I'm thinking of replacing it with the hd33 what I'm hoping is that I can just mount it where the 76 was. The lens on the old 76 was 3.41m away from a 1.70m wide screen.
The fella in the shop reckons that it will work but I'm not so sure. there is a bit of play on the mount 3.4m to 3.6m away from screen but to move it any closer would be a real nightmare, I would be grateful for any advice thanks.
toddy28
I had an in76 and now a hd33 and it's a prefect fit didn't have to move a thing 0 keystone :D
toddy28
92 " screen at 11 foot
toddy28
Quick posts as the iPad keeps crashing have about 10 secs :D
d0mm13
Cheers, this is what I thought would any of you know of a PJ that would suit my set up?
rentagas
Established Member
Why not buy a bigger screen!-that's what I did. These projectors are very immersive on an 8 foot screen.
The hd83 produces a smaller image.
d0mm13
I can't really get a wider screen in the bay window with out bringing it forward, I've been looking at the Epson EH-TW6000 this appears to have the throw I need, I mainly use the PJ for Xbox has anyone got any thoughts on this projector
cheers
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
