hello! Purchased a pc from these very forums about 5 years ago and it’s still running perfectly. My son has just started getting into pc gaming and I was wondering if I could upgrade the graphics card as it struggles with fortnite etc on medium settings. Specs are: intel i5 3570K CPU MSI Z77A-G45 16GB DDR3 XMS Corsair RAM MSI HD 7850 1GB Gaming will only be at 1080p. What card could this pc handle for around the £150 ish mark? Or is it worth just starting again and building something new? Many thanks for any help... Rick
A GTX 1050ti or a 1060 -(which will be better) will do the job , which would be around the price your look at , have you got a decent cool on that CPU? , with it been a K version you can overclock it , which would help a little bit in getting a few extra FPS within games .
Yeah has got a decent cooler, I have a look into overclocking it. I’ll also look into the 1060. Thanks a lot, Rick
You want the 1060 6GB model, which is more than £150 I'd go for this personally. Similar speed to the 1060, a lot cheaper and you get two free games. Powercolor AMD RX 580 8GB DDR5 Red Dragon Graphics Card | Ebuyer.com Or buy second hand. A 1060 6GB should be in your budget 2nd hand
Also, download MSI afterburner and mention CPU usage. Fortnite should be ok, but other games may be bottle necked by your processor
Yea , i was thinking second hand while typing , just forgot to mention it , i did have a quick look on ebay and there's few going for that price ( 150ish) the RX 580 is a choice too, but seen as i have never used an AMD card , i can only recommend what i know.... but seen as you get two games free , the 580 is worth buy i guess .
Thanks for all the replies, appreciated! Power supply is more than enough for the 1060. I’ve just put an offer in for a 1060 6gb on the forums for £145, just waiting for a reply. I was thinking second hand but forgot to mention it also... Cheers guys!!
Nice one! You can overclock that CPU pretty nicely too as long as the temps are ok. Should be able to hit 4.2/4.3 easily if you're lucky maybe 4.5. With your new GPU that will be a nice 1080p gaming machine you have.
Cheers! My son can't wait now. I'll play around with the overclocking once the new cards installed. Need to get him a decent keyboard now as well, wonder how long it will be before he's asking for a 4k vr ready beast of a pc!!!
