Quantcast
upgrade from z2! any recommendations?
jamiev
hi, i am soon thinking of buying the z2, but i am finding it hard to demo one.
i am wondering if i will be happy with the pq?
what do you recommend would be an upgrade from the z2, i will be spending up to £2000 (max).
i will be using pal prog scan, 10m component connection, and projecting from approx 11 foot away!
any ideas or comments or experiences will be grateful!?
:confused:
:boring:
buns
First guess would be at the sony hs20 or alternatively a low end dlp IF you arent bothered with the usual problems
all the best
ad
jamiev
i am thinking of buying the z2 but not convinced that i will satisfied by the pq, i should of said what is the next pj up from the z2!
:thumbsup:
nunew33
Where abouts are you in the country you may find someone on here willing to demo
jamiev
i am on the wirral
K
krlock
nexnix has a good demo room, but they are in sussex!
the z2 is a great machine, the ae500 is a great machine, the hs20 is a great machine. if you are new to projectors, then any of the above will blow you away!!
krlock
