Upgrade from yamaha rx-v440 to pioneer vsx-ax3 ?
Discussion in 'AV Receivers & Amplifiers' started by Bstar, Jun 2, 2005.
Tags:
  1. Bstar
    Bstar
    Nov 11, 2004
    Auckland
    How much of a improvement would I get from upgrading from yamaha Rxv-440 to pioneer vsx-ax3 (Which is going at a good price), my speakers are wharfedale evo 30's + centre and rears, would there be noticable power increase / quality ? Also how does the AX3 compare to the more modern models from yamaha and denon (Eg: 2805,3805, 1500,2500)
  2. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    what is your primery use music or movies? Most owners will tell you the ax3 sucks with music.
  3. Bstar
    Bstar
    Nov 11, 2004
    Auckland
    At the moment it would probably be used with a 50/50 split with music and movies, my main reason for looking to upgrade is that I am thinking that the evo 30's are not get enough power to do them justice ? Do you think I would hear a big difference in music / movies with the AX3 ?
    thanks,
  4. bobbypunk
    bobbypunk
    even worse it doesn't seem to work too well with large speakers if you can get hold of a yamaha rxv1400 or an arcam avr200 they're probably going at the same rate!
    Vsxax3 is an amazing amp with sub sats but it doesn't grip the speakers especially not with a pair that need alot of gripping to get going properly! the new vsxd2014i which replaced it has solved this problem but the going rate is a bit higher!
  5. Bstar
    Bstar
    Nov 11, 2004
    Auckland
    I can get a used RX-V1300 for fairly good price, how would that compare to the RXV-1400 and also would the RX-V1300 be a worthwhile upgrade from a RX-V440 ?
    thanks
  6. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    I would ignore the 1300 as its old tech and will be missing some of the newer and better processing options and will also be inferior to the 1400 in stereo.
