upgrade from teac AV500 system ?
Discussion in 'AV Receivers & Amplifiers' started by bbb, Sep 5, 2004.
  1. bbb
    bbb
    Hi all,
    Currently my setup is as follows:
    Teac DV-H500
    Teac AV-H500D
    Elax Linear Responce 4.6 (Fronts)
    Celestion F35C (Center)
    Celestion F10 (Rears)
    Now that I have a PC in the front room + posibility of getting a console I would like to go all digital between amp dvd/pc/console :eek:)
    now I am quite intrested in a Sony STRDB790 ( http://www.hifibitz.co.uk/product.asp?aid=17900&id=2342 ) seems to be well priced + good reviews and comments else where in the forums.
    Does anyone have any thoughts on how that would fit in with my current speaker set, or is there a better choice ?
    AV / Music usage is about 50/50, and I am quite happy with the stereo performance of the TEAC amp.
    Cheers,
    Ben
  2. bbb
    bbb
    hi all,
    I've done a bit more research, and I think either the Cambridge Audio Azur 540D (£250) or the Teac AG10D (£170) would be a good upgrade.
    Anyone know if the CA 540D dvd player is worth 200 quid, I really like matching amps and dvd players :eek:)
    BR,
    Ben
