Upgrade from my Bose Speakers
Discussion in 'What Speakers Should I Buy?' started by Terrybull, Nov 26, 2017.
  1. Terrybull
    Terrybull
    Nov 26, 2017
    2
    4
    Orpington
    Afternoon I wish to upgrade from my Bose Acoustimass 6 series 2
    Just Updated my av receiver to the Sony str-dn1080 want some better 5.1 to go with it many thanks
  2. Terrybull
    Terrybull
    Nov 26, 2017
    2
    4
    Orpington
    Budget is £700.
  3. PSM1
    PSM1
    Dec 20, 2008
    26,284
    +5,440
    Any restrictions on size or colour?
  4. david mcc
    david mcc
    Jan 2, 2015
    50
    11
    belfast
    +9
    Good evening gents I am also thinking about an upgrade to my ancient bose acoustomas 10 system . Can I change the center speaker on its own or do I have to replace all speakers
  5. PSM1
    PSM1
    Dec 20, 2008
    26,284
    +5,440
    You want at least the front 3 speakers to be the same make and model.
  6. david mcc
    david mcc
    Jan 2, 2015
    50
    11
    belfast
    +9
    Thanks for the reply is there any recommendations
  7. PSM1
    PSM1
    Dec 20, 2008
    26,284
    +5,440
    What's your budget? Do you have an avr?
  8. ShanePJ
    ShanePJ
    Well-known Member AVForums Sponsor
    Jun 20, 2006
    2,770
    Unit 5 The Sidings, Bacup, Lancs, OL13 9RW
    +718
    Going from a Bose system to another Cinema speaker brand @ £700 will do two things. Because Bose exaggerate the bass levels you may find that most system at this price point look a little flat and almost lacking in bass. But you will gain, midrange that will creating a vast amount more clarity which means you'll hear more than just breaking glass.
    Q Acoustics 3000 5.1 Speaker package
    Q Acoustics 3010 Walnut 5.1 Speaker Package - Q Acoustics - AudioVisual Online - UK Home Cinema and Hifi Specialists
    These would be my first point of call as they are a good all round speaker solution. They are quite a bit larger than the Bose System you already own.
    After that, I would say you need to add I would say that you'd be better off adding a better subwoofer once you have the capital to upgrade it so you can bring some of that kick back into the room
    Subwoofers - AudioVisual Online - UK Home Cinema and Hifi Specialists
    You'll see that the Q Acoustic Subwoofer was over £300 at launch if you have checked our list of woofers above, but choosing an an alternative like Rel Acoustics TZero you will gain a significant upgrade over the Q Acoustics subwoofer when you are ready
    REL TZero Black Subwoofer - REL - AudioVisual Online - UK Home Cinema and Hifi Specialists
