Upgrade from all in one system
Discussion in 'AV Receivers & Amplifiers' started by bcopping, Jun 7, 2005.
  1. bcopping
    bcopping
    May 24, 2005
    508
    28
    Brecon
    +46
    I currently own a Samsung HT-DM150 which i am thinking of upgrading. All the speakers including the subwoffer are attached by "springey clips" (highly technical term!!).
    I was wondering if it is possible to buy a new reciever and use the old speakers until i can afford to buy new ones? Looking at the back of new recievers the subwoffer seems to be attached with a different type of cable. Would i need to buy a new sub at the same time?
    I have about £750 to spend at the mo, probably the same again in about 6 weeks time.
    Any advice on reccomended recievers & speakers / upgrade paths would be much appreciated.
    Will be used entirely for movies. For the DVD player i would like to use the philips dvp630 that is currently being used in another room.
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    What type of speakers can you accomodate, floorstanders, stand mounters or lifestyle? What size room?
    For the £750 you could buy a reciever and new speakers especially if you look at the Canton special offer on the forums.
  3. bcopping
    bcopping
    May 24, 2005
    508
    28
    Brecon
    +46
    the room is roughly 5m x 5m, with low ceilings (2m). The room is also my office so i cant really have floorstaders as their are desks down the left & right hand sides.
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
