Upgrade from a Denon 3802
Discussion in 'AV Receivers & Amplifiers' started by TimF, Jan 31, 2003.
Tags:
  1. TimF
    TimF
    Thinking about an upgrade from this amp and would welcome any thoughts.
    I could spend about £1500 (including trade in for 3802) and am looking for a better processing unit - good steering etc.
    I use better quality front speaker power amps by Linn and I am only interested in the AV amp for multichannel sources (i.e. not CD)
    Not bothered about a tuner - don't listen to radio.
    I want master audio delay (potential plasma lip sync issues)
    I was thinking about either Denon AVC A11SR or Yamaha DSP-AZ1.
    Any views whether the upgrade is worthwhile generally and if so any preference for either of my shortlisted units?
  2. sounddog
    sounddog
    Dec 11, 2002
    3,440
    107
    Leicestershire, UK
    +477
    Not sure about the Yamaha ... but I'm pretty sure that you need to go for the A1SR to get master delay - it's not on the A11SR. Alternatively you need to look at the new 3803.
    Victoria
  3. TimF
    TimF
    Victoria
    Thanks - A1 SR is out of my price range at the moment.
    I wonder if the 3803 will be a worthwhile upgrade from 3802?
