happhhitachi
Established Member
Currently running 5.1 but have new fronts due to arrive soon (B&W 684) which will free up the MS302's currently doing duty as front surrounds.
Next upgrade will be the centre to a matching B&W unit, followed later in the year with an Amp upgrade hopefully to a second user Yamaha DSP-Z9 or somthing in that class...
So whilst Amp grunt isnt currently too lacking (Yammy DSP-A2) something like a DSP-Z9 most definately wont struggle.
This leaves me wondering if I should take the oppportunity of using the soon to be redundant MS302's as front effect speakers and move to 7.1.
the cost would be small, wall mount brackets, some conduit and speaker cable. However the room is small 4m wide x 3.75 long x 2.75 high.
Would value your opinion here, is this worthwhile in a small room, would the extra 2x front surrounds make much difference?
Opinion/comment/suggestion?
