Upgrade from 2 to 4 Atmos speakers (or not)
swanny78
I am relatively lucky in that I have a symmetrical rectangular room (converted single garage) and my speaker placements in my current 5.2.2 setup are pretty spot in with Dolby recommendations. I have recently upgraded my receiver and now have an additional 2 channels. I could add to my setup so make it 5.2.4 or 7.2.2. I am considering the 5.2.4 setup by adding 2 additional ATMOS in ceiling speakers to complement the 2 I already have. The issue is the 2 existing speakers would need to be shunted forward a couple of feet to be "Dolby perfect" needing me to drill 2 other holes and fill the existing 2 - I don't really want to do that. Would it be acceptable to leave where they are and mount the 2 additional ATMOS speakers at the rear as per the diagram attached. Red arrows show where existing 2 should move to. It wont be Dolby perfect but Audessy on my Denon AVR 3700 would compensate for that I think or should I go thru the hassle of moving the existing speakers, will it make a massive worthwhile difference. ?
Alternatively I could add 2 rear surrounds so have a 7.2.2 setup, is that more worthwhile than 4 ATMOS channels.
Any expert thoughts and ideas welcome.
P.S I know the Denon has 2 pre amp channels that I could use and have both the 7 surrounds and the 4 ATMOS 7.2.4 but maybe that's a future consideration but not for now. I have a family to feed ;-)
jang15000
I know the itch of wondering if 4 speakers are better than 2. In an ideal placement they will definitely improve the soundstage. I've moved from 5.1.2 to 5.1.4 and definitely noticed the improvement.
If you're committed on 4 Atmos then I would try how they sound with front speakers in current position. Unfortunately some compromises needed to be had depending on the room. My rear speakers are behind me...just! In an ideal environment I'd like them further back. However room calibration should adjust accordingly. What I have noticed is moving front Atmos from top middle to top front increases the overhead soundstage so you notice the front to back panning.
Pumauk
What Atmos speaker are they? Look fairly large?
Why didn’t you go into the ceiling in line with the Dolby placement suggestions?
gibbsy
You would need to have the second set of ceiling speakers placed behind the main seating area but inside that of the surrounds in a 5.1.4, Pointless having the four ceiling speakers in front of the seating as this will not take that bubble of sound behind you.
Get your trowel and paint brush out. :smashin:
jang15000
They're actually quite small. 5.25" diameter Kef ci130QR. Just managed to fit in pelmet and saved cutting into ceiling.
They're aligned with front left and right as per Atmos guidelines.
Samsung Micro LED, Mini LED, NEO QLED TVs and More: AVForums Podcast Interview
