Upgrade dspa1 to dspax1or add power amp?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by bug, May 25, 2001.
  1. bug
    bug
    Hi all i am looking to upgrade would i be better off adding a power amp to my dspa1 or getting the dspax1?
    The speakers i use are the mission cinema 8 package, Also are the front effect channels any good worth getting mission 780's for?
    Thank you all for any advice :confused:
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    IMHO not worth getting the AX1, the difference will not justify the expense.
    Rather add some power amps and replace the A1 later with an AV preamp/processor.
    Haven't tried the front effect channels yet.
  3. bug
    bug
    Reiner thanks for the advice mate, I'll book a demo with some rotel power amps :D
  4. Guest
    Power amps... Most indeedilydoodily neighbour!
  5. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    has any forward seeing company thought of making a 6 channel power amp?
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    6-Channel amps:
    Cinepro 3K6
    Rotel RMB-1066
    Rotel RB-976
