Alright so I'm in a bit of a quandary here. I bought a gaming desktop from cyberpower PC in 2013 and am now questioning if I should dump money into upgrading it or buy a new laptop for gaming. I'll throw in the spec list at the end. I used the PC mainly for a year or so of world of warcraft. It hasn't received too much usage since I bought it so I haven't upgraded a single piece of hardware. Now that I'm beginning to entertain the idea of WoW gaming again, I'm not sure how much of my hardware needs to be replaced. I used it a bit about a year ago and the HDD(I think) was starting to go out. I'm a novice to say the least when it comes to working on my rig so keep that in mind before you want me to tear everything out and replace the motherboard(which may need to be done at this point idk). When upgrading the memory, I wanted to make the switch to SSD but I think my liquid cooling system is only for hard disc? I just have far more questions than answers and just want to know if this rig is a lost cause or if I could make it work by just swapping out a few pieces of hardware. My performance needs are essentially to play world of warcraft at descent FPS and highish graphic quality. Sorry if that's too vague. Let me know if I didn't explain something enough or if you have any other questions
Spec List:
Code: BLKPEARL $1,587.00 x 1 $1,587.00
CyberPower Black Pearl
*BASE_PRICE: [+1220]
BLUETOOTH: None
CAS: * Cooler Master Storm Stryker Full Tower Gaming Case w/ 200mm Fan, Integrated Fan Controller, Front USB 3.0 & X-Dock, and Easy Carry Handle [+26]
CASUPGRADE: None
CD: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
CD2: None
COOLANT: Standard Coolant
CPU: Intel(R) Core™ i7-3820 Quad-Core 3.60 GHz 10MB Intel Smart Cache LGA2011 (All Venom OC Certified)
CS_FAN: Maximum 120MM Color Case Cooling Fans for your selected case [+15] (Green Color [+0])
ENGRAVING: None
FA_HDD: Vigor iSURF II Hard Disk Drive Cooling System [+21] (1 x System)
FAN: Corsair Hydro Series H90 High Performance Liquid Cooling System 140MM Radiator & Fan [+46]
FLASHMEDIA: None
FREEBIE_VC: None
FREEBIE_VC2: None
GLASSES: None
HDD: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Drive)
HDD2: None
HEADSET1: AZiO GH808 USB Circumaural Gaming Headset w/ Foldable Microphone [+43]
IEEE_CARD: None
IUSB: Built-in USB 2.0 Ports
KEYBOARD1: AZZA Multimedia USB Gaming Keyboard [+5]
MEMORY: 16GB (4GBx4) DDR3/1600MHz Quad Channel Memory (Corsair or Major Brand)
MONITOR: 19" Widescreen 1366x768 Sceptre X195W-NAGA 5ms TFT Active Matrix LCD Display LCD (Black Color) [+125]
MONITOR2: None
MONITOR3: None
MOTHERBOARD: (SLI/CrossFireX Support) MSI X79A-GD45 Plus Intel X79 Chipset Quad Channel DDR3 ATX Mainboard w/ Winki 3, OC Genie II, 7.1 HD Audio, GbLAN, 3 Gen3 PCIe X16 & 4 PCIe X1
MOUSE1: AZZA Optical 1600dpi Gaming Mouse with Weight Adjustable Cartridge [+4]
NETWORK: Onboard Gigabit LAN Network
OS: Microsoft(R) Windows 7 Home Premium [+0] (64-bit Edition)
OVERCLOCK: No Overclocking
POWERSUPPLY: 800 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready
RUSH: NO; READY TO SHIP IN 5~10 BUSINESS DAYS
SERVICE: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS: None
TABLET: None
TEMP: None
TUNING: None
TVRC: None
USB: None
USBFLASH: None
USBHD: None
USBX: None
VIDEO: NVIDIA GeForce GTX 660 2GB 16X PCIe 3.0 Video Card [+82] (Major Brand Powered by NVIDIA)
VIDEO2: None
VIDEO3: None
WNC: None
Spec List:
BLUETOOTH: None
CASUPGRADE: None
CD2: None
ENGRAVING: None
FLASHMEDIA: None
FREEBIE_VC: None
FREEBIE_VC2: None
GLASSES: None
HDD2: None
IEEE_CARD: None
MONITOR2: None
MONITOR3: None
SPEAKERS: None
TABLET: None
TEMP: None
TUNING: None
TVRC: None
USB: None
USBFLASH: None
USBHD: None
USBX: None
VIDEO2: None
VIDEO3: None
WNC: None
