Upgrade concerns can any 1 help???
Discussion in 'Blu-ray & DVD Players & Recorders' started by leejay, Mar 20, 2006.
  1. leejay
    leejay
    Hi everyone sorry if this has already been discussed
    I have just upgraded my tv to a samsung LCD HD ready le26r41bd, and I have a concern about my dvd player which is a ronin p807
    When I play a dvd through the ronin, the picture is ok, but not brilliant and sometimes the picture changes from light to dark, I was expecting this because my new tv is so powerful but I was wondering if there are any better dvd players, that would make the film look a lot better on my tv
    any recomendations???
    or it just could be me asking too much lol
    many thanks
  2. kjt2004
    kjt2004
    Dec 16, 2005
    1,762
    Surrey
    +165
    What connections has the new lcd got and whats your budget?
    or are you waiting for hd players?
    Obvious choices are
    Toshiba sd350e
    Samsung 850/950
    Philips 5900
    Oppo 971
    regards
  3. leejay
    leejay
    I am connecting dvd at the moment via a scart my budget is £300
    what are hd players??
  4. rhino2k
    rhino2k
    Oct 20, 2005
    6,077
    +1,283
    personally i would'nt worry about HD players (HD= high definition, new format of very high capacity media, but you'll have to buy your films all over again to take advantage :eek: )
    so, scart and a poor dvd player are your problem, get one of the players mentioned above and a decent hdmi cable and you should be sorted :smashin:
  5. leejay
    leejay
    so i would need a hdmi to hdmi? dvd player and this would give me better picture than the scart??
  6. rhino2k
    rhino2k
    Oct 20, 2005
    6,077
    +1,283
    much much better, you wont believe how much better in fact :smashin:
  7. rhino2k
    rhino2k
    Oct 20, 2005
    6,077
    +1,283
    oh sorry, yes you need a HDMI-HDMI :smashin:
  8. leejay
    leejay
    but if i was to have a hdmi - hdmii i wouldn't be able to play my backup dvds or foreign would i?
  9. rhino2k
    rhino2k
    Oct 20, 2005
    6,077
    +1,283
    afaik there wont be any problems, as long as it's region free (usualy done via remote hack). i don't know much about HDMI but is'nt the copy protection stuff to do with HD-DVD's? to stop pirated versions of them playing?
    there's also a problem with upscaling some content i think, but unsure tbh.
