Upgrade an old lg to a £600 65"??
jakewalsh
Hi everyone,
Ive been longing for a bit bigger tv,
Our current tv is an older lg49uj635v
We have:
Sky q hd
Netflix
Prime video
Disney hd
We use all as much as each other tbh, and very rarely watch sports
Sound is done via a sonos beam
Viewing distance is about 3.5m
Im wanting to spend around the £600 mark, now ive read the guides and seen a few say about the hisense having image blurr which i will pick up, so may annoy.
Ive seen the phillips on sale the 58"
And
I have also see a Samsung on sale, i see these get frowned upon though
I cant justify over £1000 for oled, so just wondering whats best,
Cheers jake
tvdavid
on your list, I would pick the Phillips 58 I would say
vickster
None of those unfortunately if you want usable HDR performance (other than the above Hisense which was being flogged at a reasonable price by Costco, maybe all gone)
Look at high tier for HDR performance (mid tier at a push)
jakewalsh
Yeah i was looking at that hisense, but its out of budget
One thing ive found is if i use disney through sky it doesnt trigger the hdr settings on my tv currently.
Cheers so far
jakewalsh
I could take a hit in size for better quality viewing
Theres this
vickster
Yep and the motion blur is probably less problematic if you don’t watch sport.
Can you buy from somewhere other than Currys though?
tvdavid
yes go for that 55 inch one
jakewalsh
Like anything the more you look the bigger the rabbit hole, i believe it has full local dimming too
Costco have it on sale too.
tvdavid
Lets us know how you like it when its set up.
jakewalsh
Tv has finally arrived
Atm im not sold on it, was expecting more of a wow factor, maybe its just that i dont have the settings dialed in
Dodgexander
Should just need to use cinema night, and then tweak motion settings. Make sure to disable fast startup in the tv's settings to avoid a bug where the motion settings don't stick after you've set them.
As with all 4k models, things like Sky HD aren't going to look great. Should be a different matter entirely with high quality content like UHD and HDR streams. Try to watch your sources in native 4k if you can.
jakewalsh
Yeah i found that one out with a bit of googling, your right about sky, sky q hd still not amazing, think sky has always dumbes down its contents.
Ive been testing with things like the mandolorian thats where i saw the screen flickr. Thats gone since i took fast boot and enhanced hdmi off.
The brightness settings through me a tad as anything really over 50 makes the whole panel grey.
Really got me second guessing my purchase now,
I know i was looking at the Samsung UE65TU7020KXXU and i know it wouldn't be as good hdr, but would it give similar sky q viewing? @Dodgexander
Cheers jake
jakewalsh
Oh here it is in my room
Dobbyisfree
Is that called a War of the Worlds lamp? 🤣
Dodgexander
It won't be better, its not until you reach the Samsung Q60T (Quantum Lite Processor 4k) and Q70T (Quantum Processor 4k) that they have dedicated picture processor chips.
Upscaling of the TV won't be used at all if you're using Sky Q with the UHD box, that'll handle taking the HD signal to 4k for you.
Some HDR is broken, Mandalorian and a lot of HDR shows are very subpar, you can see more on that here:
As for brightness, best not adjust that. It doesn't do the same thing as brightness used to do on TVs. Instead use the backlight setting. You won't want backlight very high for SDR, but for HDR it should be on 100.
Here's a good video on the settings:
What exactly were you expecting from the TV? And what is it that you aren't happy with compared to before?
Is there anything your old TV does better?
Are you watching the TV direct in front, or at an angle? The U8Q has very narrow viewing angles compared to your old TV, and will look washed out if watching from the side instead of directly in front.
jakewalsh
Thanks for the in depth reply,
Ive just put aladin on through Chromecast with google tv, image looks very pixelated, perhap im seeing the bad motion thing that people see?🤷
I did watch that second vid for settings, i dont know what i was i just presumed it would be a night and day difference from my old to new, viewing im sitting bang on infront.
Ive boxed it back up, im going to return it
Just put the same aladin on and the film looks better on the old lg, so not sure what thats about.
jakewalsh
I think im seeing the black smearing, old tv while cheaper doesnt do this. Granted blacks aint as good.
I presume the lg is an ips panel? Perhaps better suited to my eyes?
Im really unsure what to do now.
Dobbyisfree
Have you tried a less compressed video source, such as a UHD Blu-ray?
Latest News
What's new on Blu-ray Special - The Cinema of Zhang Yimou & Gong Li
  • By Mark Costello
  • Published
Black Friday 2021: What you need to know
  • By Andy Bassett
  • Published
AVForums Podcast: 24th November 2021
  • By Phil Hinton
  • Published
Panasonic 2021 TV update brings full 4K resolution with VRR and HFR
  • By Andy Bassett
  • Published
Best Hi-Fi Products of 2021 - Editor's Choice Awards
  • By Ed Selley
  • Published
