Upgrade Amp and DVD Player advice to compliment Kef Eggs
Discussion in 'Home Cinema Speakers' started by Mr Andrew, May 19, 2003.
  1. Mr Andrew
    Mr Andrew
    Having recently purchased the Eggs I would like to upgrade both my DVD player and Amp. I currently have a Samsung 709 and a Yamaha RX-V496RDS.
    The sound at the moment is very bland, a bit boomy and I cannot play many disks (CD-R/RW amongst others) on the Samsung hence the need for an upgrade.
    I am looking for advice on AMPs and players that go well with the Eggs
    The Amp has to have all the toys, i.e. Prologic II, DTS ES etc but additionally it must be good with music and something that will make the most of the Eggs
    I can spend around £800 on both the player and Amp
    Current thoughts are the Pioneer 656 and the Marantz 6300
    Any thoughts/experience/opinions?
