Upgrade advice sought...
Discussion in 'Home Cinema Speakers' started by MrJubbly, Jan 3, 2004.
  1. MrJubbly
    MrJubbly
    Nov 30, 2001
    87
    Cheshire
    This is probably one many similar requests that get posted here.
    Basically I want to up upgrade my now dated speaker system and would really appreciate some advice as to what packages I should review/demo.
    Here are some details regarding my current set-up:
    Amp - Denon 3802.
    Front Mains - Jamo 65 Cornets.
    Center - Jamo Center 100.
    Rears - Can't recall what these are. They are Kenwoods that I got with my very first AV setup.
    Sub - Celestion CSW
    The room is 18ft wide by about 12ft deep. I am looking at spending a maximum of £1200 which I was hoping would include a new Sub and floorstanding mains.
    I have spoken briefly to a dealer I know, when I first started toying with the idea of upgrading. At that point in time I was looking at the Mission M5 series (M53, M5C, M5DS & M5AS). The dealer also suggested I consider the KEF Q and Wharfdale Pacific EVO ranges, though I don't know what ones in particular would fit my budget. Any views on these?
    Any help most appreciated.
    Regards,
    Jubbly.
  2. MrJubbly
    MrJubbly
    Nov 30, 2001
    87
    Cheshire
    Is anybody able to help me on this?
    Kind Regards
    MrJubbly
  3. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Your dealer has recommended three good speaker ranges to you. Were I you I'd opt for the Mission M5 series if you can get hold of them (they've been discontinued).
    The Kef Q series are also good, but the mission M5 series is a 'movies first' kit, and would suit your AVR3802 well.
