upgrade advice please 1k ish
Discussion in 'Hi-Fi Stereo Systems & Separates' started by ddos, Jun 12, 2008.
  1. ddos
    ddos
    Feb 20, 2007
    22
  2. padi89
    padi89
    Apr 22, 2006
    185
    +6
    Generally the greatest sound improvement will come with speaker choice first,next an amp to properly drive your choice of speaker and then a CD player.Its not a rule of thumb but more a guideline , find a speaker you like then make sure that speaker works in your room then amp/cd or cd/amp, only way to know is by going somewhere to listen.
