upgrade advice needed for a novice
Discussion in 'Arcam Owners' Forum' started by ajaz, Jan 17, 2005.
  1. ajaz
    ajaz
    I currently have a humble ( but very musical) A65+ integrated and would like to consider my upgrade options. Can anyone offer some pointers? I was thinking of adding a P80 to bi-amp, but can I use the A65+ as just a preamp or does it have to be used to drive the tweeters when connected to a P80.
    Is it possible for me to use a P90 with the A65+ ?
    Appreciate any advice you can offer.
    Cheers.
    Ajaz.
  2. Commited
    Commited
    how about selling the A65 and trying to pick up an A80 second hand?
  3. ajaz
    ajaz
    I really need to hang onto the A65+ for the time being, but may change it at a later date. Just would like to know if the A65 can be used as just a pre with say a P80 driving everything and would it be feasible to add say a P90 instead to my integrated.
    Any help much appreciated.
    Ajaz.
  4. Commited
    Commited
    afaik it can be used as a pre or bi-amped with any of the arcam poweramps.
  5. ajaz
    ajaz
    Thanks for that. Now I just need to find out if I can bi-amp the A65 using a single P90?
  6. Sweden
    Sweden
    yes you can biamp w the p90. john dawson said that some time ago if remeber right. search in the forum
  7. Commited
    Commited
    Thats pretty much what I said above.
    Sorry if it wasnt clear
  8. Sweden
    Sweden
    Yes the P90 will work very well in this set up - use it to drive the woofers and the A65 the tweeters and go for it :) Don't forget to remove the links on the back of the speakers before doing this though.
    John Dawson (Arcam)
  9. ajaz
    ajaz
    Many thanks to everyone for your help. I think a P90 is the way forward for me.
